Coolest pipe sanding tool
  • Coolest pipe sanding tool
    http://www.youtube.com/watch?v=AG8Z5GpkCRo What do you guys think? No more expensive wire brushes, I'm buying one.
    Re: Coolest pipe sanding tool
    That is AWESOME,THANKS
      why would he show a 1 x 3/4 x 1/2'' tee and only demo the 1'' fitting cleaning?
      i don't think it will clean a 1/2'' fitting or 3/4'' fitting
      also it only cleans pipe for pre fabb. not pipe in place.
        Doesn't appear to save much time overall either.
        I believe I can clean a fitting or pipe just as fast with sandcloth
        or a fitting brush and not have to drag a drill around with me or
        have to worry about charging batteries, etc.
          i gut off the handle of a 3/4 wire brush and put it in my cordless drill and clean all sizes of fittings 3/4 and up .i can do a lot of fittings with one brush and the batteries last all day .
          i just did a job where i had about 75 1 1/4 and 2 fittings ,it helps a lot
          i do like the way it cleans the pipe but i will still use my open mesh sand paper in my hand
            i bought this lil tool from the guy off ebay.. its way to finicky paper falls out you can only clean a certain amount of fitting and pipe sizes.
              It seems like a lot of work to use it..
              I do cut off a brush for my drill if i have a lot of fittings to clean
                It looks cool but those cheap brushes bernz-o-matic makes work pretty good too, even when the pipe is in place. I like the fact that it can take re-usable sandcloth though and do inside/outside diameters. Pretty cool.
                  Your fittings and pipe shouldn't be that dirty anyway.
                  I'm sure I can clean faster by hand. And I can carry the sandcloth in my pocket.
                  How does it clean up the rest of the pipe? Or does he just put it in dirty and leave it that way?
                  I did cut the end off about a 1-1/4" brush and stuck it in a cordless to clean bad Sloan valves . . . You can wrap some green pad around it and polish real nice.
                    While I agree with all the previous comments, I gotta admit it's nice to see people coming up with new ideas and putting them out there for manufacture. Though this invention may not be the end-all in pipe cleaning, it is clever and will probably spark someone else's imagination. Keep 'em coming, America!
                      Hey we are all on the Rigid web sight. You would be better off getting one of these.
                      http://www.youtube.com/watch?v=RWwYv..._embedded#t=77
