Old Standard urinal flush valve
  • Old Standard urinal flush valve
    Anyone know where I can find a new flushing mechanism? From what the customer said "it flushes, but then it keeps running a little."
    Thanks.
    Re: Old Standard urinal flush valve
    I got i valve almost like that at my local plumbing shop except it had a button. It would stay on for a flush and then shut off..
    It was 1/2" pipe thread and chrome finish..
    put it in about 12 years ago and it still works fine
      The "Faucet Shoppe" in Chicago.
      3844 N. Elston Ave.
      773-478-3890
      They can ship it to you.
        Here is a cod approved Chicago valve that will work for you. http://www.chicagofaucet.com/catalog...ID=21&manufact=
          Opps here is the push butten one I like better. http://www.chicagofaucet.com/catalog...ID=21&manufact
            Great! Thanks for the leads. I printed out some specs, and am going to see how they look. The one with the vacuum breaker is a couple more bucks.
              With that ofset, why not use a Sloan or Zurn valve?
                The Faucet Shop actually has the valve with vacuum breaker
                  Coming out of the wall it appears to be 1/2 inch.
                    When I had to do these for a church last year Ferguson and William F Meyers had them in stock as well. I was suprised how commen they where, since I hardly ever see them.
                      Ugh. I took the cut sheets over to check some measurements. From the top of the urinal to the center of the handle currently is 6 inches...too short. I even added an inch into the top of the urinal. I really need to get a handle.
                        Try looking at ...Marksplumbingparts.
                        they have the Chicago urinal valve with the handle,,,but no vac breaker
                        part #22264
