Street closet flanges???
  • Street closet flanges???
    I was wondering if any of you guys has had trouble with street closet flanges.....I might need to use a 3" one and since the inside diameter is only about 2-1/2" i was wondering if they are more prone to clogging or leaking. It has a red rubber that seals against the inside of the 3". Do they make one that you can glue into the 3" pipe that is also deep (4")?
    Re: Street closet flanges???
    "Danger Will Robinson"
    Ahh I've seen worse.
    What happened?
    Don't tell me.He did it himself.
    Can you chip outside for a hub?
      If i am doing something new ..it will be 4" pipe for the com i dont care what the code says should work..If 3" is ok 4" is better
      If it a remodel , with 3" pipe ,i use a 4x3 reducing 90 and glue into the 4"
        IPC. No insert closet flanges.
          I have used them before. They work GREAT!.
          They just do not pass code here in michigan.
