Cleaning up purple primer????
  • Cleaning up purple primer????
    My helper dropped a small splatter of purple pvc primer on the painted walkway of a building. Is there a cleaner that will clean it up? Steam clean?
    Re: Cleaning up purple primer????
    I usually use clear primer, just keep swabbing at it. It may not come completely out but it'll fade it drastically.
      you beat me to it. that works on tubs too.
        and the vinyl around sliding glass doors <.<
          i believe acetone is the solvent that will break it down.
          try a little experiment with it on a sample cement stepping stone or block.
            i think rick is correct. i keep pvc cleaner on truck. use it with shop-vac. breid.............
              I would spill primer over the entire 4' section of sidewalk so the few drops aren't as noticeable.
                THe clear primer worked just fine but thanks for the acetone tip also.....I hope I never have to try it though.
                  I prefer to use clear primer on my work for that very reason. Accidents happen. Problem is that some inspectors want the purple used to show you're using it at all.
                    Another vote for acetone, I drink the stuff
                      plumb4life
                      Florida Code requires the use of purple primer. No other option is provided, even on trim out. Kinda sucks.
                      Mike
                        in PA you need to use purple primer for plumbers but for HVAC piping you dont
                        and i never had an inspector say any thing about condensation drains and clear primer
                          Acetone will damage plastics, but the purple primer will probably also damage the same material.( The PURPOSE of primer is to "damage" the plastic!) Just be careful around such material.
