vessle sinks
  • vessle sinks
    What is Your preference for faucet outlet to sink rim distance? Isee a lot of different ideas on this.
    Re: vessle sinks
    Whenever someone goes with this I require them to have both available at the rough-in.
    Then have a little "Pow-Wow" with them about where things are going.
    I hate doing it twice. So, the quick answer is I don't have or know of a preference.
      Re: vessle sinks
      Only done a few. Always in granite so already predetermined for me. Meaning holes already drilled. have had issues with the plywood underneath not prepped properly
      Same plywood issues on granite kitchen sinks. If I'm doing rough on kitchen remodel I give the countertop fabricator a heads up.
      I get cabinet guys all tore up when I request no stile or no full wood back! So far no refusals after I explain my reasoning
      wookie
        Re: vessle sinks
        I prefer not to even see one go in a house.
          Re: vessle sinks
          Yea some of the worst ideas in plumbing survive by being fashionable.
          411 Plumb Appliance Stimulus Package
            Re: vessle sinks
            If done right a vessel sink works just like any other type of hand wash fixture. The trick is making sure the water from a normal flow from the faucet strikes about an inch back from the edge of the drain (pop up or grid). That way the angle of the bowl will cause virtually all of the water to head towards the drain and not upward. If the spout is set too far back (towards the back wall of the vessel), getting ones hands under a full flow without major splashing or their bumping into the back of the bowl could be problematic.
              Re: vessle sinks
              Make sure you get the homeowner to ok the placement of everything. Like JC, I also require to the homeowner to have the cabinet, sink and faucet on the job site. Most manufactures state 1" above the flood rim but if you look at trade magazines they are some 6" or so. Its a style thang!
                Re: vessle sinks
                This is some freebe work for a neighbor. I fabricated a stainless Steel frame support
                for the sink assembly. Other neighbor , Harry the plumber , another former marine Bud,
                plumbed, another tiled. We have a good Hood. Why free? He's a freebe football coach,
                and Has raised 2 Great respectful Sons.
                  Re: vessle sinks
                  In that case, he won't mind a little splashing.
                    Re: vessle sinks
                    Tool,
                    I usually suggest 6". I think they are not for everyday use, but before rough in, I set the sink on a table outside & elevate it so it doesn't block the drain hole, connect the faucet to a water hose and hold the faucet in place for a test. I had a non-aerator dornbracht faucet that if you let the water hit behind the drain, the water would turbulate, run up the back of the bowl & flow over the rim, move the faucet an inch forward or back and it worked OK.
                    Make a quick drawing & pack it away with the vessel.
                    Avoid non aerator type faucets.
                    Kohler grid drains suck....
                    Bryan
                      Re: vessle sinks
                      Thanks We went with1 1/2" ABOVE FLOOD RIM. Looks great. I'll send pix to Rick,
                      Can't figgure how to post.
