Hot water tempering valve?
  • Hot water tempering valve?
    I got called to a restaurant they had interimintant hot water. Boiler was fine heated to thermostat temperature and shut off then relitwhe it cooled enough. It ran hot then would cool very quickly. I think it is either a bad check valve or a bad tempering valve or both.
    Will a tempering valve allow cold water through to the hotside or is there an internal check valve?
    Re: Hot water tempering valve?
    The ASSE 1070s have integral check valves, the ASSE 1017s don't.
