Adjusting Grohe Thermo Valve
  • Adjusting Grohe Thermo Valve
    Do what I'm suppose to do. Adjust the valve to 100 degrees ,when on the 100 degree setting. Assemble set to highest read out 110 My thermometer matches. Know the E Mail is coming,it does in the Morn. The shower isn't warm enough for Us! I explain,I knew that,
    Grohe Lawyers love cold showers. Ran it up to 120 degrees. Yes I'll save the E mail, I really don't have to, nice folks!
    Re: Adjusting Grohe Thermo Valve
    you need to adjust the high limit reset override to a safe enough level so the user is well aware that they are going to increase the potential scald danger.
    some of the higher end grohe valves have the override, others have an integral high limit you set prior to installing the handle. make sure you install the limit and stop plates.
      Tool
      Which Grohe thermo valve are you talking about? They all can be adjusted, with a max temp equal to (less heat loss in transit) the temp of your heat source.
      Contact Tom Slankard at Western Sales (N. CA Grohe rep) for details.
      tslank@western-sales.com
      1-800-289-5687
        Thanks Guys, followed adjust procedure. top temp. after a few minutes of run time is set at 120 degrees. I was always told that is the safest highest temp. Will get back with model #s a little later. Thanks.
          Mine has a little red button that let's you go up to 130. The button kicks in at 100 degrees on the dial.
            What the heck you guys talking about? Little red buttons? Kicking in at 100?
            My wife said that I got the only Grohe in this house...now I'm in big trouble....
            (The Low Spark of Steel-Toed Boys)
              The little white line shows what temperature the water should be. There is a red button on the dial:
              If you don't press the button, there is a stop that prevents you from going over 100.
              If you want a hotter shower, just press the red button, and you can turn it as hot as the water source.
                No red buttons ! I HATE RED BUTTONS!
                  [ATTACH]8452[/ATTACH]
                  [ATTACH]8453[/ATTACH]
                  [ATTACH]8454[/ATTACH]
                  We don't allow fancy stuff like that up here---never did, never will.
                  Mainly because the nearest big city is 3 hours south and those darn southerners charge way too much for too little.
                    I wonder if your's can be set to scald before the override.
                    Just making a point for those in the future digging for info.
                      Grohe, Hans Grohe, Dornbracht and Jado can all be set so the stop button is at any temp desired (within the range of available temps) by a knowledgeable adjuster. In some cases it's as easy as removing the handle cap, loosening the handle screw, turning the handle and retightening the screw.
                        Only knowledgeable adjusters ,I know, work for Allstate
                        Just a dumb Irishman trying to read the GROHE SMALL PRINT
                          Noted
                            A knowledgeable adjuster is one who has paid his/her tuition. I got my learnin' by having to calibrate dozens of valves after the heating system has been turned on in all the houses we've done. I forgot to mention that along with a screw driver, you might need an allen wrench set (SAE or Metric) and you'll definitely need a thermometer.
                              Probably, since I'm sure it isn't properly adjusted since I've had to take it apart and put it back together (and before that I'm sure the WH was replaced at least twice).
