Suspended water heater
  • Suspended water heater
    pretty tired at this point, and started thinking, so i'm going to post and pass out.
    I was considering installing a tankless exterior water heater for my house for the space savings. But in my stupor something else crossed my mind. I Could suspend a lowboy from the ceiling in the corner of my garage using 5/8" allthread and either a pan designed for this, or a pan sitting on unistrut that gets held up by the allthread. I'd have to special order a couple of earthquake straps to keep it from tipping over for any reason.
    So basically, toss some ideas at me, I like to think about how I Could do things in my home, a lot of the ideas fall by the wayside but some of them even get implemented.
    Re: Suspended water heater
    Here's what I do with my house:
    I pretend the wife is a customer calling in for a estimate. I look at the job and give her a price. Since its always after hours and weekends, its double/triple time and 300% markup on the price.
    If she goes for it, the job gets done, by and by. If the price is too high, tuff luck....she'll have to wait until I find my bike key.
    (The Low Spark of Steel-Toed Boys)
      EQ STRAPS 1/2" ELEC. EMT cut to length hammer both ends flat for 2 1/2" drill for 3/8" leg bolts and washers. works great! post pix please
        yes
        i have been using the ceilings on jobs for 40 years. make it good and solid, your good to go. all the rules on the ground work in the air. breid.........
          5/8" threaded rod is a bit over-kill...I'd go with 1/2". One in each corner is MORE then enough for a lowboy.
            I was thinking the same 1/2"is plenty
              I've always been pretty bad about overkill. what do you guys use Under the heater? I was thinking unistrut but if there's a pan designed for it i'd rather use that.
                I am also the king of overkill....but being a pipe fitter also, I know how much weight 1/2" can support...times 4. I would do unistrut and two layers of 3/4" plywood on top. Just place the pan on top of that.
                  3/8" Allthread @ 4 corners, Unistrut and 2 layers of 3/4" plywood.
                  I just bid a set of prints last night with this set-up for a 20 gal electric.
                  Bill
