New way to join PEX
  • New way to join PEX
    Went to a job today, guy called and told me on the phone that he just installed new PEX tubing and everytime he turned the water on it took about 5 seconds and a joint blew apart. Thinking his crimpers might be out of adjustment I showed up on the job and to my suprise found all new PEX tubing glued into CPVC fittings with purple primer and PVC cement, everything right from the meter all the way up to the second floor bath. He told me this is the way the associate at Home Depot told him to do it.
    Re: New way to join PEX
    well if the guy at HD said it would work then.....he probably listened wrong. Either way LMAO
    Seattle Drain Service
      He probably misunderstood the guy. I'm sure what the person at Home Depot said was to run the water lines with CPVC, but to join them with PEX fittings. That makes a lot more sense.
        So did you get him all fixed up?? or is that on the menu for tomorrow?
        Makes you really wonder what some people are thinking
        G3
          I ended up redoing the whole thing. There were a couple of pieces I could salvage but it kinda liked like the purple primer monster attacked everything.
            Thanks for the killer chuckle!!
