Help with Roman Tub valve
  • Help with Roman Tub valve
    I have to go fix a roman tub valve. The diverter is on the spout and when you lift the rod to divert water to the spray head it doesnt stop the water from the spout completely. Im just gonna take the trim off and I hope there was just some debris in there. If you guys have some tips for me I would greatly appreciate it.....
    Re: Help with Roman Tub valve
    You know the drill. Make, model, yada yada yada.
      I'm not sure I have seen a spout diverter that will stop completly when pulled.
      If it was a deck mounted diverting valve it would shut off completly.
      Big Jim is right on that the starting point is make, model or at least a picture ect ect...
