Burns
  • Burns
    What do you use for burns? Had the copper bite me a little today.
    Thanks.
    Re: Burns
    for me.
    immediate cold water.
    try to think of something else for a few hours.
    Pain killer
    protect lower layers from bacteria.Neosporin and frequently changed bandages.
    How deep did you go?
    All three?
      Re: Burns
      just be careful dumping cold water on a fresh burn. If it's bad enough cold water will open the skin right up, lukewarm water or a damp warm rag are probably better if you can get them.
        Re: Burns
        for me.
        Pain killer
        All three?
        No. Pretty light this time. No reasons to complain. Just want to be thinking about next time too.
        Thanks.
          Re: Burns
          Some of the best first aid for wounds I have used is Silvadene. It is a prescription but should be easy to convince the doc to write it up. I'll almost use on my toast to start my day off right.
          It is for burns usually but I have used it on every open wound including a dog ear infection. Lavender Oil too nothing like it for burns, beats the old aloe plant hands down.
            Re: Burns
            I bought some Burn Gel from a company called Safetec.
            http://www.safetec.com/webmodules/ca...uct.aspx?ID=37
            It numbs the pain almost immediately. If you want a few packets P.M. me and I will send you some.
              Re: Burns
              remember my finger burn photos
              they're perfect and i actually cut the dead skin off with a razor knife as per joeys brother and applied neosporim.
              next time try propress
                Re: Burns
                Bacitration is way better than neosporin. Neosporin is mixed with bacitration and filler ingrediants.
                  Re: Burns
                  ProPress? Why would I ever choose an inferior joint???
                  Let's argue!
                    Re: Burns
                    A customer of mine gave me a whole jar of that...it's a straight antibiotic and came from the shriner's burn institute. The wife works there and her son jumped a firepile at a party and suffered 2nd degree burns.
                      Re: Burns
                      Let's argue!
                      because you can do it with water running and be done faster than it takes to read this post with no leaks and no burned skin
                      plus all the cool plumbers have a propress
                        Re: Burns
                        Poor plumbers don't. So sad.
                        Back to the ointments.
                          Re: Burns
                          I believe his advice was to seek professional medical attention and the above recommendation was your diy doctoring.
                          I love my plumber
                          "My Hero"
                          Welcome, Phoebe Jacqueline!
                            Re: Burns
                            I have found these to be a great help when I get a burn...
                            http://www.walgreens.com/store/store...?id=prod366129
                            JC, You could always use the poor mans propress, the sharkbite
                              Re: Burns
                              This is the same company we use to stock our first aid kits in trucks and job sites.
                              We are pretty heavy users of band aids, gauze and burn creams. The gel is better than the spray.
