Hot Tap
  • Hot Tap
    I need to make a few hot taps in a private water supply line, and I decided to purchase a set. Does anyone have hot tap kits that they recommend?
    Re: Hot Tap
    what kind of main, i use a mueller b101 setup for ductile iron, i dont know what to use for PVC mains
      Re: Hot Tap
      it's 8" DI pipe I gotta do (1)1-1/4 and (2) 1" or maybe 3/4"
        Re: Hot Tap
        I saw this on the internet from wheeler rex http://www.pipemanproducts.com/WR-Ho...ngSystem.html- what are your thoughts. does mueller make one like this?
          Re: Hot Tap
          http://www.wheelerrex.com/catalog/im...AP2_wValve.tif
            Re: Hot Tap
            The wheeler rex system is similar, I know with the mueller there is an adapter that allows you to use a r700 machine to run the cutter as opposed to just a ratchet. I havent used the Wheeler setup but i see no problem with it at all other than you must use a saddle i believe whereas with the mueller you do not.
              Re: Hot Tap
              Not sure exactly what you need.
              http://www.reedmfgco.com/index.html?...lling_machines
                Re: Hot Tap
                just looking for opinions on different brands - thank you both for the info / brands
                  Re: Hot Tap
                  My 2 cents. I would include the equept. cost in this bill. I'd never break it down,or customer would HOWL. Has always worked for Me on reasonable $ amounts. Maybe a good percentage at least!
