Great new tool-
  • Great new tool-
    I tried a Lennox diamond encrusted blade for cutting cast iron today.
    I had a job with the cast in a bad spot. cast crackers would be tough to use and an angle grinder would have been a pain. At the plumbing supply house I saw the new blades and asked about them. A young guy said they work great. I figured what the heck. Then I was told $18.00 per blade. I thought man this better work. first started cutting and I was thinking this aint so great. Then I got through the outside of the pipe. and WOW did it cut nice. the 4th cut went slow cause the blade was worn but I'm extremely happy with my new find. from now on all cast getting cut gets build an extra $18.00. it was easier to handle than a snapper especially over head on a ladder. and way safer and cleaner then an angle grinder. Lennox did a good job with this one.
    It aint as great a toilet seat bidet but it sure is good.
    Re: Great new tool-
    Used one yesterday. Best thing for compromised cast cut.
      Re: Great new tool-
      What's the Lenox part no. for the blade?
        Re: Great new tool-
        Here's a link that might help. They don't cut super fast, but are safer and can give you a place to connect where the chain would bust spots on the older CI. Also probably only going to get about 5 cuts out of 1 blade. And the last cut will be tough in my opinion.
        http://www.lenoxtools.com/enUS/Produ...ip_Blades.html
          Re: Great new tool-
          You just described an identical statement that Mike mentioned to me today.
          I'd say, when you get that 4th or 5th cut, have a brick close by and run that blade into the brick; that should clean the blade if it gets gummed up with what you're cutting. That happens with carbide fused blades and my diamond blade angle grinder wheel.
          Brings it instantly back to life.
            Re: Great new tool-
            I've used the Milwaulkie version a couple times same results as the lennox it looks like.
            wookie
              Re: Great new tool-
              i was given 3 of them over a year ago to play with. still a grinder or snap cutter is faster. but these are much faster than the original carbide grit blades.
                Re: Great new tool-
                I thought so. We've been using these for about a year now. Only problem I've had was when I ordered a batch of them, they were on back order.
                  Re: Great new tool-
                  Every service truck should have a diamond blade. And 2 if you are doing any kind of remodeling work.
                  Sure snappers are fast but they can leave sharp edges that you have to go back over with grinder otherwise risk shredding a no hub coupling.
                  Grinders cut like butter, but are not practical indoors (like on a bathroom remodel where you have to cut the stack in a finished hallway or basement). The dust will make a huge mess.
                    Re: Great new tool-
                    I bought some of these a while back but haven't had a chance to use them yet. Sounds like a good idea.
                      Re: Great new tool-
                      Yupp used them in My Tunnel from Hell Job ...LOL
                        Re: Great new tool-
                        I've tried these things before and didn't get particularly great results. I'm now thinking that I might have been using the carbide grit blades Rick mentioned. I cut a fair amount of cast so this could be a boone.
                          Re: Great new tool-
                          Like soomeone had mentioned above, I have used Milwakee"s with good results.I am curious how they compare with the Lennox blades.
                            Re: Great new tool-
                            I've been using the angle grinder as far as comfortable then finish with a Milwaulkie blade. Most of my cuts are in a tight crawl space so i'm always looking for the easiest method to giter done.
                            wookie
                              Re: Great new tool-
                              I tried one once that was a "remgrit" or something like that. The cutting edge was the fattest part of the blade
                              It cut about anything I tested it on... sorta.
                              The package listed just about anything as things it would cut, but it seemed to work best on metal and concrete.
                              Until now, I didn't realize anyone else made them... I'll have to see if I can order some.
