Nitrogen use idea
    Re: Nitrogen use idea
    CAREFUL! They could take an eye out with that spoon
    Oops,I forgot.
    We are responsible for those who should not be using any tool other than a spoon.
      Displaces oxygen inside pipe to prevent carbonization.
      Thanks, did not even think about that for brazing. It is done that way on stainless all of the time when tig welding, we call it back purging.
      G3
        this only works for inside of the pipe. i replace the hw drain valve with full port ball vavles.
          how about a SCUBA tank/regulator rig instead of N2?
          3000 psi in the tank (80cu/ft) and adjust the 1st stage for 100 psi (most regs use an IM of 90 psi). you even go with a smaller bottle like 20cu/ft BOB or a pony bottle.
          just a thought
          steve
            I bet a Water Ram would work as well.... If I had one I would try it
              bill, i'll be glad to sell you mine. it's collecting dist on the shelf,];. only been used a couple of dirty t-shirts times
                I would buy it but I trust your opinion and I have managed to make it this long without one...
                • #23
                  the ram seems like it would be neat, but it also seems like it would only work if the clog were between the drain and the vent, with no overflow or any other point of entry for air.
                  • #24
                    G3
                    I weld and use tri gas on SS. c-25 mild steel ,Argon for Allum.
                    • #25
                      Be a hoot at a party. Use in the 2nd bathroom,with a few plugs on the roof vents. KER POW
                      • #26
                        I bet it would be better then flushing a cherrybomb...lol
                        • #27
                          You guys are sick........where can I get one?
                          www.ClinkscalesSeptic.com
                          • #28
                            the only time i used Argon was in a tri-mix deep dive. thought i was gonna freeze my nads odd. no wooly bears or pumped hot water. what a dumbass i was. so young and so stupid
                            steve
                            • #29
                              Just a question, but what part does the nitrogen play in brazing?
                              G3
                              An often overlooked "best practice" by shade tree HVAC technicians. They will soon find out ( Jan. 1, 2010) that if you cut that corner on R410, you will probably have a failed compressor soon!
                              • #30
                                With a water heater pump you can remove the top mounted relief valve or hot water nipple out of the hot side of the heater and push down a rubber washing machine hose and pump the tank dry.
