L or K copper For water service
  • L or K copper For water service
    I have been using soft K copper for under ground water service leads. But it seems of late that soft L copper is about $60.00 cheaper a roll. I was always told that L is for Gas, and K is for water. Do you think L is useable on water service?
    Re: L or K copper For water service
    What matters is what is allowed by code in your state.
      We use it in the buildings for commercial work, if the inspectors will allow it then it'll be fine. but it won't have the same durability as K
        There is a reason its cheaper...its thinner. Did you see my post about the bad water service??
        http://www.ridgidforum.com/forum/showthread.php?t=29072
          good luck finding type k out here. only time i've seen it was for government work. in fact we use to be able to use "m" for underground.
          now the only time i ever buy m, is if i'm doing pressure relief valves that typically will never see water.
          L is all i keep on the truck.
            On a remodel, if the existing tube is M, we stay with M. Otherwise, it's L.
              Building homes,Cape Cod Mass. 1970. L service everywhere. All domestic water plumbing in the home L . M for Hydronic heat ONLY. Roof flashings ,lead or copper. These homes
              sold for $30,000 on your lot! Good days
                Have always only used type k for underground service. Though the last few years lots are using plastic (puss-pipe) for underground service. Not sure how crazy I am about that, but the times thya are a-changin.
                  tat blue cts tubing is tough stuff. had a local utility provider replace a supply from the tap to the meter with that stuff on a saturday morning. they left it draped across the road all weekend. dug in a new one monday morning.
                    I remember homes on wells, using plastic all the time 40 years ago! Are folks using copper off the well head today?
                      Around here the plastic is used on wells. Copper on houses, and in some cases the plastic.
                        For my area, the copper main is or has pretty much been gone for awhile on anything 1" or below.
                        Typically 1" black PE pipe rated to 160psi. Very few problems seen honestly. Once in awhile someone calls for a leak where someone put lower pressure "thin wall" black PE in and expansion/contraction/vibration against a stone or brick from construction rubs a hole in it. But even that is often 15 years down the road.
                        Type L roll copper is more than adequate for this area. Water chemistry will play some roll in longetivity but also you should think about soil ph and it's tendency to degrade the copper prematurely. If that's the case you might have to sleeve it in some vinyl pipe sleeving.
                        In short, Type L should be very adequate.
                          we use k copper for water services in OHIO, home of ridgid tool and yes the OSU BUCKEYES!!!
                            Check your code, we cannot use L for the water service here in Wisconsin.
                              Copper tubing is rated as K, L, and M. These letters relate to the wall thickness. JUST BECAUSE IT IS M TUBING DOES NOT MEAN IT IS FOR HYDRONIC HEAT!!!!!!!!
                              Your code book will tell you what has been approved by your administrative authority!
