Micro Inspection Camera
  • Micro Inspection Camera
    Does anybody know of an inspection camera that will go inside of a 3/4" plastic water service?
    Re: Micro Inspection Camera
    how far do you need to push it and do you need to locate the camera?
    you're not expecting the camera to make a 90 turn are you
    the micro explorer will push out 30' with extensions with the 9mm head. i need to measure the coupling of the extensions, but i'm pretty sure they are less than .75''
    .7'' camera and i believe the extensions are the same. http://www.ridgid.com/Tools/Undergro...gies/index.htm
    the seesnake microdrain is also 30' and is locatable. not sure if it will fit 3/4''. actually it's .86''
    http://www.ridgid.com/Tools/SeeSnake-microDrain
    josh will have all the dimensions.
    nice screen name
      Just tested it (micro extensions) in 3/4" PVC in my office. Gets through just fine.
      Here's the catch, your not going to make turns in 3/4" pvc with the microEXPLORER and extensions.
      Also.. the microDrain will fit easily into 1 inch but will not fit into 3/4"
      Josh
