Abs vs pvc
  • Abs vs pvc
    why do they use abs here in california? what advantage does it hold over pvc other than no priming needed?
    Re: Abs vs pvc
    Funny , We both have East coast experience. You'll see all PVC back EAST, ABS out west.
    I'm told PVC is superior. I just have way to many ABS FITTINGS.
      Re: Abs vs pvc
      ABS pipe is cheaper. At least it is for me.
        Re: Abs vs pvc
        ABS and the fittings cost more on the East Coast! Go figure.
          Re: Abs vs pvc
          I only see abs on trailers here. when I look at a piece of it in lowes, it looks like heat made it curve or contort.
            Re: Abs vs pvc
            Im in MICHIGAN and ABS Is NON Existint.
            We use only pvc. I would not even no where to buy ABS or even if it is available.
              Re: Abs vs pvc
              I'm also in Mi. I have never seen abs sold. If I work on a trailer I have to transition with fernco's to pvc.
                Re: Abs vs pvc
                Toronto, Canada is 100% ABS (above ground). Drive across the border to Buffalo, New York and it's all PVC...go figure!
                  Re: Abs vs pvc
                  There is a TRANSITION GLUE to glue directly from ABS to PVC.
                    Re: Abs vs pvc
                    Channel Island University spec'd PVC for their residential units less than three floors in height.
                    The plumbing contractor had an in with the supplyer on it,tens of thousands of dollars dropped his price low enough to where he could give future developers a discount if they went with PVC.Not a hard sell when you convince the owner it's also a superior product.
                    Which it is.
                      Re: Abs vs pvc
                      I did not know this. I guess i'll shelve my instant disdain when I see them glued directly together.
                        Re: Abs vs pvc
                        Same thing around here in the middle of IL.
                          Re: Abs vs pvc
                          we mostly use abs in n.e. ohio.
                            Re: Abs vs pvc
                            not code according to ipc
