Your Toolbox - essentials
    Re: Your Toolbox - essentials
    Here goes
    Small drain bag ( drains up to 2")
    10 inch pipe wrench
    12 inch pipe wrench
    9 1/2 inch channellocks
    12 inch channellocks
    10 inch vise grips
    7 inch vise grips
    8 inch adjustable wrench
    12 inch adjustable wrench
    4 in 1 screwdriver
    #1 phillips
    #2 phillips
    Cheap long reach needle nose pliers
    mini hack saw
    flash light ( led tripod type)
    small pry bar
    7/16 nut driver
    5/16 nut driver
    rector seal
    teflon tape
    ruber gloves
    leather gloves
    a few rags
    a few plastic grocery sacks
    small can of wd 40
    Large Drains and sewers
    Cordless work light
    dead blow hammer
    regular hammer
    16 inch channellocks
    12 inch Channellocks grip lock
    10 in channellocks
    10 inch vise grips
    15 inch adjustable
    12 in adjustable
    14 inch pipe wrench
    18 inch pipe wrench
    razor knife
    medium sized prybar
    cold chisel set
    recp saw blade holder
    5 pair rubber gloves
    2 pair leather gloves
    rector seal
    teflon tape
    can of liquid wrench
    shop rags
    can of lysol
      Originally posted by PlumbingHelp.ca View Post
      LOL.....45 and business cards
      Well they need to know who you are and you mean business all at different times.
      PR department and collections department
      G3
        RIDGID? ARE YOU LISTENING?
        A good, metallic, fitting level would be pretty handy.
        jc i have 2 ridgid 9'' torpedo levels with glow in the dark markers around the vials. it has 3 magnets that will properly hold it upside down.
        i won them at the roundup on the 3 power threader /oiler race the day before the games.
        bill, their just about done re plastering and painting the walls
          Ok guys this is just some of the stuff i carry commercial plumbing is all i do.
          Pipe Wrenches (1) 10 (2)14 (2)18 (2) 24End wrenches one 10 18 24
          Chain wrenches
          Spud wrench offset
          lever tubing bender 3/8 & 1/2
          bolt cutters 14''
          Channellocks 440 430 420
          Screwdrivers
          Hammers ball pein 16 oz 24 oz double face 3lbs 12lbs 20'' handle
          Deep well Sockets
          Mini HackSaw
          Adjustable Wrenches
          Flashlight
          Basin Wrench
          Internal Nipple Wrenches
          Cold chisel
          Cape chisel
          Masonry Chisel
          Needle Nose Pliers
          Kleins
          Side cutters
          Half & round files
          Hand Torches
          B-tank
          Tubing Cutters 151 152 153 101
          Tape Measures 25' & folding rules inside read
          Allen Wrenches
          Utility Knives
          sink rim screwdrivers
          Oil feter wrench
          Tin Snips
          Angle grinder metal cuting wheels wire & cup wheels
          Sawzall
          Band saw
          Hammer drill
          Extension Cords
          Trouble lights
          IRONS 2 packing 2 caulking 1 ceiling 1 offset 1 inside
          Ladle' lead pot' rune rope
            I wonder how many know what these are let alone how to use them.
            G3
              G3
              I did forget to mention I have caulking irons, joint runner, lead pot, and a furnace on my truck as well.
                I keep the typical stuff on the van but I always try to have a 6-1 screw driver and a small set of channel locks in my front pocket. I don't feel like a plumber without them. I like having a flashlight handy also. Yes I'm happy to see you and that is a screw driver in my pocket
                • #23
                  Quote:
                  G3
                  I agree, As far as tools i think all of the previous posters have covered all of the bases for me.
                  • #24
                    Why would they do that? when I get back there I'm just going to mark my territory again
                    I use my fitting level a lot when doing heat work. I agree, the plastic ones are crap and break when I smack them with a wrench.
                    • #25
                      The problem I had with the plastic ones were they cross threaded too easy, and then would not thread at all.
                      Do you have one made out of some type of metal?
                      G3
                      • #26
                        G3
                        Could be wrong, but I don't think Rick and PC are thinking about the same thing we are. We all probably have some sort of magnetic level to lay across fittings or on pipe.
                        G3 and I are talking about a level that has threads on the end to screw into fittings. At least that's what I am talking about.
                        • #27
                          Here is one I found laying around in the basement.
                          It is made by spot rite
                          When sammy screws first came out they gave these away if you collected the points cards that were in the boxes and sent them in.
                          G3
                          • #28
                            G3,
                            check this link out.
                            http://www.pipefitter.com/index.html
                            the tools here are sweet.
                            Bogart
                            • #29
                              Originally posted by g3sprinklers View Post
                              i wonder how many know what these are let alone how to use them.
                              G3
                              +1
                              • #30
                                found them on sammy screw page
                                http://www.sammysuperscrew.com/pdf/TIME%20SAVERS.pdf
                                G3
