Butterfly valve installation
  • Butterfly valve installation
    Got a 1 1/2 butterfly valve in last week for this navy job I'm currently on. Never seen one so small(that's what she said). I've only seen 2" and bigger. Anyway, this one is shaped just like a sweat ball valve. Question is that on THE disk, there's an o-ring. I've always seen and used the type with a resilant seat and no o ring. Will there be any damage to this o ring if I sweat the darn thing in? The valve is at the jobsite so no pics.
    Re: Butterfly valve installation
    You should wipe the solder with a wet rag.
      Then check the joint with a mirror.....thanks for the plethora of information. Where my buffing wheel? Gotta shine some some joints up.
        Ben, you have any info on the valve, make, model or figure number that I can look up on the net?
        I've worked with plenty of butterfly valves up to 84", but never run across an 1-1/2" one.
          Tin the pipe prior to sweating the valve.
          Direct the torch flame away from the valve.
          Keep a spray bottle of water handy to quench the valve.
            Here's the valve. When we order stuff for the Navy projects, we have to put "or equivilant" on every LI. Unfortunantly someone thinks that this is equivilant to a ball valve.
              It's a sweat valve, sweat away.
              I'd sweat open with maybe a cooling towel near the middle.
                What about the dental mirror?
                  Don't make me tell you where that goes.
                    Mmmmmm Butterball....
                    West Trail Mechanical Ltd
                    www.westtrailmechanical.ca
                      What JC said. Least amount of contact between the disc and body to less chance of damaging the o-ring seal.
                      What is the application? Does not matter what some dumb purchasing agent 'thought' was a ball valve. If the butterfly valve is not the correct type then don't use it. Could it create a safety risk using this valve? Is the o-ring material compatible with the process fluid? Does it have the proper pressure rating and approvals for the intended application?
