Shark Bites or compression fittings?? Page Title Module
  • #61
    Re: Shark Bites or compression fittings??
    Maybe he means Jaws? Congratulations.
    • #62
      Nope it was the P&M Ridgid Tool tip contest, $200.00 in free Ridgid hand tools. Here's the link:
      http://www.pmmag.com/CDA/Articles/Tool_Tips
      Also if you look down I got the Dec. 2009 too!
      Hey it's something, anything free these days is great!
      Send Us Your Tool Tips >> If you have an idea that has saved you time and money, Plumbing & Mechanical would like to share your tip with our readers. E-mail us and the first-place winner each month will receive the following RIDGID® Prize Package, consisting of eight professional hand tools with a retail value of $200:
      • 18-inch HD RAPIDGRIP™ Self-Adjusting Wrenches for easy, one-hand operation.
      • One-Stop™ Wrench, a compound tool for installing compression couplings.
      • 10-inch Wide-Mouth Adjustable Wrench featuring tapered jaws for tight areas.
      • 10 1/2-inch Plumber’s Tongue-and-Groove Pliers with extra-wide openings.
      • No. 117 Midget Tubing Cutter for use in confined areas.
      • No. 151 Quick-Acting Tubing Cutter for smoother operation.
      • 6-in-1 Multi-Purpose Screwdriver with two Phillips heads, two flat heads and two nut drivers.
      • No. 395 Nightshade Torpedo Level for general use and work in tight and/or dark areas.
