Better Wax Ring?
  • #31
    Re: Better Wax Ring?
    What evidence was there to say they installed it improperly?
    The penetration through the floor was too large so the piece of cardboard they use to help the sticky stuff didn't work plus the bowl still had the old wax residue on it. When the water closet was pulled, the adhesive part was an inch below the horn.
    • #32
      Originally posted by Clipper City Plumber View Post
      That is crazy plumbers using putty that is outlawed out here for the seal to the flange you can use it along the base of the bowl. I have installed about 10 of the fluidmaster waxless type however lately I have had problems too many closet flanges installed on top of tees so i've been back to wax , wax with horn,and stacking rings ect. all you need is a good putty knife and rags I mean we are plumbers right a little wax never hurt
      Here you go right from the Illinois plumbing code. The last setance is the part about we are able to use plumbers putty.
      Section 890.360 Water Closet and Pedestal Urinal
      Fixture connections between drainage pipes and water closets, floor outlet service sinks and pedestal urinals, and earthenware trap standards shall be made by means of brass, copper, hard lead, plastic, or iron flanges; caulked, soldered, screwed or solvent welded to the drainage pipe. Flanges of hard lead, plastic and iron flanges for no-hub or compression joints shall be secured to the floor. The connection shall be bolted, with a gasket, washer or setting compound, between the earthenware and the flange. The floor flange shall be set on an approved firm base. The use of putty or non-drying plumber's putty manufactured specifically for plumbing installation is acceptable.
      • #33
        one would be putting a lot of faith in the adhesive where movement is common.
        Eljer had a problem with a similar "permanent" adhesive in the ultra one toilets.
        • #34
          Originally posted by TOPDAWG View Post
          In my 25 years in the plumbing trade I have only seen one toilet set with putty and when I pulled the toilet, the putty was rock hard and the floor was rotted.
          I've never had a problem with putty in over 10 years. Had one today where the wax slid during adjustment (I didn't put the wax ring on). Didn't leak, but caused a big stink of sewer gas.
          Putty was ok for my grandfather (and great-grandfather) when they installed the toilets and piping systems that I service today and it's ok for me too. Not for everyone, and I understand that. This is akin to drum vs. sectional. You use what you're comfortable with and what has proven to work for you.
          P.S. Thanks for the quote Ron, I know we can always count on you and Mark for accurate code info.
          -Chris
          • #35
            I'm sure a drop head toilet auger would rip it out or damage it. I'll stick with wax
            Rod
            http://unclognh.com
            • #36
              I remember the first time I seen putty used as a seal.
              WTF...
              Crap was rock hard and broke off in two inch chunks.
              I love wax, it gets all over my hands sometimes, and when it is cold, it is SO easy to work with. Love that stuff really. I was actually looking for a more primitive way of making that seal. Any ideas?
              • #37
                We have to use National Standard Plumbing code only Maryland and New Jersy use this code. Plumbers putty is only allowed as a base and can not be used as the seal.
                • #38
                  Is there such a thing as non hardening putty?
                  Or is it non hardening if it is totally sealed away from air?
                  Cause ALL the putty I have ever scrapped off sinks, or pulled from under toilets, was hard
                  • #39
                    This is why I use putty over wax about 75% of the time.
                    Pulled this stack off of a 5 y/o Kohler Wellworth tonight. the rings were stuck to the bottom of the bowl and never even made contact with the CI flange. Never leaked when flushed, but leaked like all hell when the line backed up. The horn is probably the only thing that kept it from leaking when flushed.
                    • #40
                      Surprised they didn't have any problem with sewer gas smell.
                      • #41
                        If the wax isn't deep enough it won't seal. If the putty isn't deep enough it won't seal either. The wax isn't the problem, the plumber was the problem.
                        • #42
                          I'm sorry, but triple stacking wax rings is asking for trouble
                          • #43
                            How to remove a WC after 50 or more years, that was installed with plumbers putty.
                            • #44
                              Thats why I wouldn't use putty, because in 50yrs when you want to remove the toilet, it may break, and you would have to buy a new one. Nothing lasts like it used to, LOL.
                              • #45
                                i too had a toilet horn snap off due to putty.
                                a properly installed flange and wax ring is set for life. no leaks period.
