pipe dope
  • pipe dope
    i was wondering what kind of pipe dope most of u guys and gals use i use the light blue mega loc i like it because it comes off stuff real easy i also use teflon also on most things too but never plastic over metal if i can help it
    Re: pipe dope
    Many do just as you do for the same reasons you do.
      Re: pipe dope
      that is the same dope I use
      ________
      Gs750s
      Mike
        Re: pipe dope
        Rector Seal #5 (For Steel)
        Blue Monster Teflon (Tape and Paste) for the rest.
          Re: pipe dope
          Me too.
            Re: pipe dope
            i usually put dope on 1 then teflon over it if i do it the other way then as the tape peels back then so does the dope is this right?
              Re: pipe dope
              I have never used both (tape and paste)
              I hear of guys that do and if I remember correctly they tape then paste.
              If you wrap your teflon tape in the right direction it will not unwind and will actually cinch to the threads
                Re: pipe dope
                Rectorseal #5 for most things
                Teflon tape for smaller threads
                Sometimes I'll teflon the males and Rectorseal the females.
                  Re: pipe dope
                  Blue Monster Tape and Dope or Gasoila dope.
                    Re: pipe dope
                    I use the same technique but use the edge of the teflon tape reel to start on the beginning of the thread and go around like three times, this pushes the tape well into the treads and avoids the tape being pushed out.
                    Simon
                      Re: pipe dope
                      Wow! I thought I was one of few who used Blue Monster. Because it's hard to find here. I had to call direct and order. Major suppliers here don't stock it. Use the tape and dope; good stuff from our friends in Australia mate.
                        Re: pipe dope
                        rector seal. Thats all I use. I buy it by the case
                          Re: pipe dope
                          #5 on steel, T+2 on plastic.
                            Re: pipe dope
                            Has anyone ever spilled a can of the Yellow Rectorseal into a bin in your tool box?
                            What an unbelievable mess.
                              Re: pipe dope
                              #5 for rough
                              MegaLock for trim
