pipe dope
    Re: pipe dope
    Blue Monster tape & Laco Slic tite dope on water piping for us.
    Rectorseal TRU-BLU for gas.
    I tape, then dope on water. no tape on gas
    -Chris
      Re: pipe dope
      Put me first on the hater list of MegaLoc. I used it for two years and call it Mega Lumps.
      I use Oatey Great White. I like it so far.
        Re: pipe dope
        rectorseal #5 for anything but plastic, Plastic gets cheep supply house teflon tape.
          Re: pipe dope
          Either Blue Block, or Rectum Seal.
            Re: pipe dope
            Whitlam Select Unyte. Simply the best teflon based dope money can buy.
              Re: pipe dope
              I use it also, good stuff. Also use Rectum Seal #5, & Leak Lock.
              James
                Re: pipe dope
                mill-rose 3 wrap water and/or laco slic-tite. am i to believe that monster is better than pink with mill-rose? all i do is water, steam or gas. breid...............
                • #23
                  Re: pipe dope
                  Originally posted by speedbump View Post
                  Has anyone ever spilled a can of the Yellow Rectorseal into a bin in your tool box?
                  What an unbelievable mess.
                  yes That's why i ues MegaLoc now.
                  • #24
                    Re: pipe dope
                    Originally posted by boytyperanma View Post
                    Rectorseal #5 for most things
                    Teflon tape for smaller threads
                    Sometimes I'll teflon the males and Rectorseal the females.
                    Thought it was against code to paste females?
                    And just bad practice? Since threading will push that away from the desired seal, then will go downstream and clog things up. This correct?
                    And ALL I use is Monster, but I have wet dreams about key tite
                    I like my pipe dope, like I like my sex.
                    THE MESSIER THE BETTER
                    • #25
                      Re: pipe dope
                      is blue monster a brand name?
                      • #26
                        Re: pipe dope
                        Here you go.
                        http://www.cleanfit.com/70885.html
                        • #27
                          Re: pipe dope
                          I use to use rectorseal #5 and then wrap it teflon tape. I now use Blue Monster with teflon on everything. Love it.
                          • #28
                            Re: pipe dope
                            Doping females is against code for fire sprinklers, NFPA-13
                            I use most any of the white teflon paste. Been well pleased with some that ARGO sells, will stick to wet or oily threads and is smooth. 2 1/2" threaded pipe and bigger I will use dope then tape, trick is to not put too much dope in the threads that the tape gets pushed off. This is what works for me.
                            Rector seal #5 is good stuff also.
                            I am not into the dope that sets up solid, sure is a ***** to get back apart and not really needed in my opinion, just put a little more arse in it and tighten up that pipe.
                            Most seem to want to rely on the dope to make the seal instead of the threads themselves.
                            G3
