Homemade fusion welded fittings
  • Homemade fusion welded fittings
    Done fusion welding hdpe pipe and was taught how to make your own fittings. The machine even comes with the attachments to allow for this. While talking to another plumber, he mentioned this is against code as the "homemade" aren't allowed. Any thoughts?
    __________________
    Re: Homemade fusion welded fittings
    ben, the conversation was based on waste fittings
    you can fab anything you want. but don't expect it to be approved by an inspector as it's not a listed fitting.
    water fittings are not as critical when it comes to restrictions and sweeps. waste is.
