See this often?
  • See this often?
    Do any of you see this often? San-Fran you don't count.
    This is like a once in a lifetime encounter for this area, so I had to grab the camera. I know of only two houses out of thousands done in DWV copper.
    Thought it might be interesting to some.
    Re: See this often?
    There is not a lot of it here but there were several subdivisions built with copper DWV.
      Re: See this often?
      JC that had to be copper................that's outdoor plumbing
      G3
        Re: See this often?
        We owned a 1930's Tudor that every inch of the piping was copper, a true thing of beauty. Great house with full oak trim and doors, but plaster on brick made it very expensive to heat and cool! Had to move into a newer house since this one wasn't in the right school district we wanted for the kids.
          Re: See this often?
          Very common in my area. Even more so closer to Chicago. I like copper, the venting systems corrode.
            Re: See this often?
            only time i've ever seen it is on indirect waste from a 3-comp. sink in a kitchen and a couple of urinal rough-ins inside big chases.
              Re: See this often?
              very common in my area-early 1960s
                Re: See this often?
                I see a couple a month in my area. It's mostly cast iron here with remodels and repair with pvc. I have noticed that they do corrode easy over time, not just the vents but the tops of the drains too from the gas. I like ripping it out, makes good scrap!
                  Re: See this often?
                  I have seen it on some houses in so. Calif. Areas
                  I lived in and managed a (8) eight unit apt. Building like that
                  in the LA. Area
                  all copper DWV from brass nipples behind the p-traps all the
                  way out to the street
                  JERRYMAC
                  E-MAILJERRYMAC777@GMAIL.COM
                  FIRE SPRINKLER CONTRACTOR,
                  SINCE JAN. 1989
                    Re: See this often?
                    Worked in a house today with copper dwv in it.
                      Re: See this often?
                      There is a town called Parma that we ran Copper DWV until right around 1989 - 1990. It was cast iron under ground then Copper DWV then back to 4" cast through the roof.
                      ________
                      Buy Grinder
                      Mike
                        Re: See this often?
                        My house I currently live in has all copper DWV piping. Of course I have changed some of it, while remodeling, but I would say 50% of it is still in place. They put cast iron underground, and all copper above ground.
                        Still has an inspection approval sticker on the main stack, from 1967, that also says installed by local 98 plumbers. Been a long time since any union plumbers {other than side jobs} have plumbed any residential houses around here.
                          Re: See this often?
                          In North Riverside, where our shop is located, PVC is still not allowed even for residential, so lots of copper.
                          Very common in Chicago. Anything 2" and smaller is copper for DWV, though it's type M now. DWV (yellow markings) was outlawed in IL a ways back, though you still see a lot of it in homes built from early 70's to mid 80's. That stuff is so thin that you might as well have used flue pipe! The vents get extremely brittle.
                          Had a Dentist office on 2nd floor of an office building with over 150' of DWV on the vacuum system. We repiped as the line was turning into swiss cheese.
