New walk in tub replacement with pics. Page Title Module
  • New walk in tub replacement with pics.
    1
    Re: New walk in tub replacement with pics.
    Sorry Bout your poor C/S
    Set a Kohler like yours at the turn of the century.
    Pump/Bladder seal became too much of a maintenance issue for the homeowner.
    Now it's a shower with a 22" step through diverting dam.
    Preacher could do Baptisms in your monster
      i have installed several of the walk in tubs, 3 different manufactures, after a while the door seals start to leak! thy are a pos imho!!!
        I want a walk in tub so badly ;-)
        They seem really nice,
        Thanks for sharing the pictures.
        Help With Your Pool Or Spa Pump?►WeT HeaD Pump Repair ► Watch Me On YouTube: Pool & Spa Pump Repair TV
        New: Pump Repair MagazineNew: Pool & Spa Pump Repair Forums
          It was leaking badly at the diverter valve?
          Where at?
          At the deck?
          Is the valve pre-installed?
          Thanks.
            Do those things have a pump or something to make them drain faster?
              no pump.
                Every time I see those on TV ,I laugh. Tar Baby, will stick to You for Years
                  Dis the plumbing insp. have any comments?
                    Originally posted by Tyman
                    Yes it uses a pump to drain it. It has a total of three pumps, one for jets, one for air and one for the drain. The drain pump is not overly powerful and did not cause any oscillation issues with any of the traps. Fortunately this house was plumbed well. It did cut the drain time down ⅔.
                    The diverter valve was luckily right behind the front panel which made it easy to access. However, if anything on the other side leaks, I'll be ripping off siding. The diverter valve is installed at the factory.
                    I should have taken pictures inside the unit but I didn't have my camera.
                    Sounds like alot could go wrong with that tub.
                      the walk in tubs i put in has never had drain pumps.
