safety showers
  • safety showers
    GDAY
    I am doing plumbing in very very remote area of australia
    the place is called newman
    it biggest iron ore mine in world
    anyway i have problem with eye washers and safety showers
    they are used in outdoor area the water pipe work gets very very hot
    if someone was use safety shower eye wash if an emergency they would
    get very burnt by hot water in pipe work
    the temp here in Pilbara area north or perth in western australia
    big mining area
    here is picture of what they look like
    http://www.prattsafety.com.au/safety...e_details.html
    they have a american value on them thermo temperature value
    they start leaking once the temp gets over 40 degs
    the temperature here ranges from over 40 degs to 60degs some days
    can you come up with solution how i cool the water down
    any ideas would be good
    if you want you can talk me on skype username bazzathebushman
    Re: safety showers
    Why don't they put up some kind of shade structure to keep the sun off the pipes
    If the water was the same as the air temp they should be OK
      Re: safety showers
      evaporative cooling maybe?
      what resources are availabel to cool with? Do you have an ample supply of electricity? What about water itself?
      If you had a steady low flow of water could you keep things cool that way?
