Burned thermostats
  • Burned thermostats
    What could have caused this?
    Re: Burned thermostats
    All that I have ever seen in that condition were water leaks. Almost all were CPVC pipe installed by a DIY
      Nope thats not it.
        I Failed to note that I had never seen both burnt all to Heck at same time. Oh well why ruin a perfect day and be right about something.
          was there an electrical short somewhere
            It's common, either a short in the t-stat or a bad element will cause it.
              I'm thinking not a short to ground because that should have tripped the breaker. Probably a loose connection at the lower element or t-stat that overheated, caught fire, and then followed the sheathing of the wire up.
                I have questions. What size breaker? What size elements? Obvious amperage problem, wires not twisted together at connection creating an arc, loose wires. I cannot see the wiring at the top of the heater could have had a larger sized wiring that did not throw the breaker and instead fired up the stats.
                We have many water heaters wired to a dryer connection that can carry up to fifty amps and the heater draws 17 amps. The wiring will handle high amperage without blowing the breaker causing issues elsewhere.
                  I can not answer all your questions because I am not an electrician. I can tell you that it had a thirty amp double pole breaker.
                    I guess I have let you guys take enough guesses. The homeowner told me that he had replaced the thermostats a while back and that is has not opperated properly ever since then.
                    Thanks for the replies.
                      Did he install 110 volt stats? There must be a reason they fired up.The 230 volt would not burn up unless installed wrong or pulling to many amps.
                        What made the home owner think he needed new thermostats ?
                          He likes keeping us all in limbo. WTF actually happened?
                            No need for profanity. I have not replied because I don't have all the answers. As I stated before, I am not an electrician. I don't know how to calculate amps. I got to the job, saw the shape of the heater, told homeowner it need to be replaced (he already new that). So I did. The power was off when I got there. When the water heater was full he turned the breaker back on. It has been over a week now and working fine.
                              Someone could have replaced the elements with higher voltage/amp draw on the wire setup.
