JFC fust for copper replacing solder
  • JFC fust for copper replacing solder
    I just herd of an adhesive for rigid copper only, that takes the place of hot soldering. Is anyone using this and is it code approved? Any experences with this would be appreciated.
    I just found that stuff on friday, used it on 2" copper inside a wall that was dangerous to solder in due to the presence of paper-back insulation. I belive it is code-approved in Canada, I dont know how well it holds up over time, but it definetly did the trick and saved the customer about 3hrs labour (job took about 5hrs instead of a whole day).
