prv valeve
  • prv valeve
    About an 8 month bradford white 40 gal nat. gas. I had to drain and remove temporally.
    Customer says the prv is letting off a drip and rumbling about every Hr. Will replace the Prv.
    It's set a little high on temp. Any thoughts? water pressure at 60 lbs.
    Re: prv valeve
    usually in that scenario, it tends to be a weak valve.
    put a pressure gage on the drain bibb and watch the pressure go up as the heater kicks in. make sure nothing is turned on. the pressure will creep up.
    you either have a weak valve or need an expansion tank depending on your pressure, check valve, back flow preventer, city main pressure.
    i usually find it's a weak valve or a bad pressure regulator. less than 5% of all heaters i see here have an expansion tank.
      Re: prv valeve
      You never let Me down friend! Thank You
        Re: prv valeve
        Try PlumberRick's advice, that is usually the case. At least around here, or it could be just a small piece of sediment stuck in it.
          Re: prv valve
          Thanks i changed out out the P.+ t in the afternoon. Customer agreed to pick up expense of expansion tank with check valve $260.00 . All new plumbing and waste with new prv set at 60 lbs, last year.
          Washington State code. Expansion tank on all W. heaters. What's wrong with S.F. and Ca.
