Turbo Torch Tip
  • Turbo Torch Tip
    My trusty turbo torch finally is done after 10 years of faithful service, she just won't fully close anymore. After buying a new one, I was talking to the dirtiest of hands the other day and he told me a great tip for turbo torches. I'll just let the picture do the rest of the talking.
    Re: Turbo Torch Tip
    Interesting modification there, should be patend. Have you tried the one Benzomatic makes with the hose? Sometimes it is way less cumbersome to use as you clip the mapp bottle to your belt and your free to solder with a lightweight handle and hose.
      Re: Turbo Torch Tip
      Putting that kink in the tubing didn't change the way the air enters the tip did it? I know when there is a nozzle/venturi involved and you put an ell in too close to them, it changes the flow of the water and messes things up. Same with flow meters.
        Re: Turbo Torch Tip
        I think Ben just swapped the standard STK-9 tip for the 45 tip that is stock with the self lighting model. That's pretty slick!
        I don't like that Benzomatic one. It doesn't get hot enough to do anything bigger than 1" effectively. The hose is a PITA most of the time anyway. The Turbotorch model is well worth the extra few bucks, but I use the STK-9
        I may have to add that custom shop upgrade myself.
        You guys out to start calling yourselves the Pipe Trades Think Tank
          Re: Turbo Torch Tip
          Nope, standard tip, I put the bend in myself with a tubing bender. The nozzle is 1/2" od. My tubing bender nozzles are 2' and I needed every bit of that to ben that nozzle. For thos possiblely unfamilar with bending hard pipe, always spray wd40 on your bend so it bend the metal rather than bites down and flattens it. Another reason I don't like the hose models is I remove the bottle from the canister after each day. There's quite a bit of gas in that line just to let out.
          I used it last night and I couldn't tell the difference with that bend in there as far as heat output is concerned. But that little bend really made it much easier to use. I wish I did this 10 years ago.
            Re: Turbo Torch Tip
            That's a nice bend. Thanks for the WD-40 trick. Question: When you look down the end when it's lit, (from a distance of coarse) does the twist still look the same where the flame comes down the end of the barrell?
              Re: Turbo Torch Tip
              It does. Can't tell any difference than the straight tip.
                Re: Turbo Torch Tip
                Was bending Elec. conduit last week. Like the W D 40 trick !
                  Re: Turbo Torch Tip
                  I found I wasted to much $ on the little MAP bottles.
                  A B-Tank gives soooo much more flexability and capacity. Air / Acetylene is the only way to go.
                  Like the bend and the WD is a great tip.
