a question
  • a question
    recently i have been having problems with my toilet. i am not sure what is wrong any advice would be helpful. well when i flush i get a big air bubble from where the water comes from to make everything go down and then it will fill up to the top and stay, then i have to plung it and it will go down. the other toilet in the house works fine. like i said any advice will be fine. thanks ken russo
    There are several things that can factor in on this one is have you ran a tiolet snake through the toilet yet? try that but if it dont work you may also have blocked up internal vents in the toilet its self you can try to clean them out with a piece of wire after taking the tiolet apart but i normaly replace the toilet when that happens hope it helps you out
