2-1/2 inch econo plug?
  • 2-1/2 inch econo plug?
    I cannot find one. Its for one of those older 2" floor drains. Seems its threaded, and would fit a 2" pvc threaded plug, but its stripped.
    Any leads?
    Thanks.
    Re: 2-1/2 inch econo plug?
    Any leads?
    Thanks.
    Do you want to plug the floor drain?
    Thanks.
      Elmwood Supply - Elmwood Park, IL
      try Andy he should have them
        Thanks, I will check them out.
        Yep, they need to plug the floor drain. Apparently the drain is a hair lower (or backpitched)than the 2" line it feeds into. When the laundry is discharged into the laundry tub, water overflows from the drain, and makes a mess (I am sure suds have a hand in this as well). The line is clear, (I camera'd it, and kinked my cable). It has been plugged ever since they moved in. The sewer backed up a couple of months ago, and the head pressure blew the plug. They need a new one, as the other one is dried out rubber.
        I am not done with them yet, as I am looking for the correct remedy.
