W. H. dielectric JUNK JOKE
  • W. H. dielectric JUNK JOKE
    Installed a 40 Gal. B white N. Gas W.h. about 5 months ago. Last week added an expansion tank. Pulled the NEW D.Elec. and rust at lower end. Brass nipples from now on. Think any Insps. will Hassle Me on the change?
    Re: W. H. dielectric JUNK JOKE
    tool, don't you use brass nipples and water flex connectors?
    i haven't used dielectrics in over 20 years.
      Every time I change out a heater with die electric unions the nipples are just about rusted shut. I do either copper or c.p.v.c. brass to plastic adaptors on electric and power vent heaters.
        that rick is one of the best things of being out west here. back east it wad dielects and they always rusted.
          Best thing ? For Me it's not frezzing My AZZ OFF ?
            well its cold today! i`m a shut in it is only 60
            but yea love the sunny weather
              Doesn't seem to matter that much what you connect it with these days. Water heaters probably going to die first.
                You guys have it so easy out there. Using flexible connectors to connect a water heater violates Minnesota Plumbing code.
                This week a Minneapolis Plumbing inspector informed a customer/homeowner that they have to get rid of the flexible water connections on their water heater.
                They also had to get rid of the flexible SS gas connector with which they had hooked up the gas. (they're selling the place and a truth in housing inspection caught the bad gas connection. That's the only reason I was there. I also found four gas piping leaks while I was there.) So these poor homeowners thought they had to get one connection repaired, and they ended up paying triple to get the gas leaks fixed. Now they have to fix their water piping too. (Which they have not asked me to do.) They are already losing $50k on the house so they aren't happy at all and I don't blame them.
                  Can't use flex. gas connectors here in Mich either. Not sure about flex. water connectors, because I never used one on a water heater, always thought it looked like a DIY did it. And also must use dielectric unions.
                    earthquake code out here requires certain products that you guys don't.
                    we have to strap water heaters upper and lower 1/3 of the heater. also have to have automatic seismic gas shut off valves at out gas main.
                    but then again we don't have to worry about snow melting
                      THE flexes here are e quake code issues. Not a convenience factor.
                        C'mon, you know the earth quakes are an excuse for using flex lines.
                        I wish we had earthquakes here, so we could use flex everything too.
                        But seriously, you guys are right, & I know Rick said it too, dielectrics always corrode. I wouldn't use them if they weren't code, but unfortunately they are here. Do they make brass dielectric unions? Never seen 1.
                          You know... maybe we should strap our water heaters too. Once I had a water heater move about a 1/164th of an inch from all that snow melting.
                          What might be worse than earthquakes are the potholes in the roads here. Oh man. My van must look like a drunk is driving when I'm weaving down the road trying vainly to avoid the canyons of death.
                            Pot Holes , good place for your dielectics
                              I have seen many guys complain about dielectric unions being junk due to the steal part rusting up on the inside. While placing my order with Hodes I noticed they carry a brass bodied dielectric union by Watts. Watts even makes a Lead Free unit for those of you in a lead free state. http://www.watts.com/pages/_products...s.asp?pid=6856
                              I ordered up a set, and will give you all my review of it when I get them.
