Flux
  • Flux
    What brand are you guys using?
    And if you swap for winter, what brand do you swap to?
    I generally use No Corode in the summer, but, not in the winter. In the winter I use C-Flux. But it gets nasty during solder. Looking for a good cold weather alternative to it!
    My avatar, is every mans wet dream, don't lie. We all know you ride the bedroom moped
    Re: Flux
    I like Oatey 5.
      Re: Flux
      propress requires no flux
      is the nokorode a water soluble flux? or is the good stuff that we haven't used in 15+ years
      everflux seems to be the flux of choice out here
        Re: Flux
        One of my suppliers gave me a sample of flux called Fireeater. I kinda liked it. My biggest problem with the water soluable fluxes is that they burned away far to quickly for my taste. The Fireeater held up under prolonged heating, now I just wish that supplier would get some more.
          Re: Flux
          Here you go.
          http://www.drillspot.com/products/57...eater_flux?s=1
            Re: Flux
            Oatey #5 for me too, in the small 4oz cans, so I get new fresh clean flux, more often. Difference in cost is minimal.
              Re: Flux
              HA!!! You crack me up
              BTW - I used to use Otay, then Dutchboy, but I think they went under.......(Dutchboy)
                Re: Flux
                Oatey for me also dosnt burn out to quickly and dont smoke to bad
                SMELLS LIKE $$$$$$ TO ME
                  Re: Flux
                  NoKorode makes a cold weather paste flux that is great.
                  I use it almost exclusively summer and winter, but it does get rather soft when it's hot out.
                  I haven't used their regular stuff, so i'm not sure how it compares.
                  Oatey 5 has been my second choice since my first jar of NoKorode.
                    Re: Flux
                    Yes Nokorode cold weather (blue lable) it is not water soluble. Good stuff
                      Re: Flux
                      In the past I have used cold weather nokorode and yes it stays soft untill the weather gets below 0 even then cold weather nokorode gets hard
                        Re: Flux
                        liquid flux. Forget about the paste. The liquid flux flushes out of the piping system, does not burn, and does not freeze up.
                          Re: Flux
                          What is the deal with it bieng water soluable? Is that a code requirement? Or just a longevity one??
                          I have seen commercial jobs that specified non corrosive, but didn't know there was a difference between water soluble and non. Is that why c flux turns hella black and sets off smoke alarms? so annoying...
                            Re: Flux
                            don't you guys need to use water soluble flux?
                            we've had to use it for over 15 years now.
                            1 of the major reasons why i got into propress.
                            water soluble flux washes out as soon as there is moisture or vapor from within the line. no flux, no solder, big leak
                            not a big deal on new work, but a major issue with repair work.
                              Re: Flux
                              I'm with you Rick, Propress all the way these days. I use it for all my repairs and re-pipes these days. That or Viega pex.
