Monel?
  • Monel?
    Rick and Rookie Plumber have mentioned Monel seats or seals before. Don't know if I'm familiar with them or not. Could be called something different here but I'm pretty sure I just have no experience with them.
    Where can you purchase them? Who makes them?
    Thanks.
    Re: Monel?
    Monel is a specific copper nichol alloy. Great stuff if you can find it.
      Re: Monel?
      Monel bibb screws are all I use for faucet repair.
      Ruud used to make a monel steel water heater. I have seen several over 35 years old. I've never seen a burst monel water heater. We always removed them because the gas valves had a troublesome tendency to stick on. And back in the 50's when they were installed, 1/2" relief valves were commonly used (and quite inadequate).
        Re: Monel?
        tons of it on subs, ww 2, even silver ware. drop on deck,doesn't resonate to enemy sonar
          Re: Monel?
          I've removed Monel water heaters from the 40's that were still working, but that was way back when in the 80's when I was working in San Francisco. Also removed a lot of the copper tanks too, wish I still had some of those.
          When they sold them they came with a 20 year leak warranty. Nickel/copper alloy, about 25% copper. Now why don't they make them like that now! I know, cost.
            Re: Monel?
            Who makes your Monel parts? Where do you get them?
            Thanks.
              Re: Monel?
                Re: Monel?
                When I was in sonar I was taught that active sonar reflected off the air space in the submarine. Of course, I know active sonar reflects off of sunken ships so I'm not sure how much the air space actually has to do with it.
                I had to use Monel nuts and bolts on a job at a sub base once back in the late 80's. I recall they were VERY costly and I was glad I only needed a dozen or so.
                  Re: Monel?
                  Thanks.
                  I buy them at the counter of one of our local (not a national chain) supplier.
                  But, Wolverine brass sells the monel bibb screws and seats. Get ready for sticker shock,
                  Stainless steel 3/8" x 10-24 = .23@
                  Monel = 1.84@ (I pay .43@ at my supplier)
                  stainless steel 1/2" x 10-24 = .27@
                  monel = .68@ (i don't know why the 1/2" are less
                  an Eljer brass seat is .52
                  an Eljer monel seat is 4.41
                    Re: Monel?
                    No, profit, you can't make money if you only get to replace every 20 years.
                    John Ruskin (1819 - 1900)
                      Re: Monel?
                      Only a couple of companies I know of make monel seats for their fixtures. They will almost never wear out. Years ago I was able to buy some Price Pfister monel tub/shower valve seats. I would use them only on the hot side of a fixture along with a nylon washer when a tenant or home owner was cranking off the hot side so hard that washers were wearing out in days. I wish I had saved some of them for the house I am living in now.
