How I sleep at night
  • How I sleep at night
    After new copper is charged,air and flux flushed out, and under pressure, I do this. Give each solder joint a good wrap with the end of My crescent wrench. No one ever taught Me this, makes sense to Me.
    I've heard to many sad stories.
    Re: How I sleep at night
    not sure i would approach it with a metal wrench.
    if you really want to test it, try flushing it with hot water and then create water hammer with a fast shutting ball valve and cycle it as you're flushing the lines.
    the water hammer will create a spike / shock wave 2 to 3 times the working pressure.
      I do all the same Tool with the addition of bringing it up to 300 pounds and use a long piece of decent size wood so I don't have to drag a ladder around.
        If you really want to test it, try flushing it with hot water and then create water hammer with a fast shutting ball valve and cycle it as you're flushing the lines.
        The water hammer will create a spike / shock wave 2 to 3 times the working pressure.
        Rick.
        hammer handle most of the time
          i do all the same tool with the addition of bringing it up to 300 pounds and use a long piece of decent size wood so i don't have to drag a ladder around.
          better idea! How do you get 300 psi ? Air ?
            Sounds like another use for the Kenetic Water Ram to me
              you can fill the line too be tested with Water and use a hydrostatic pump. or you can charge the line with Nitrogen.
                Hardcore!!!
                  As I understand and practice it; The standard for hydrostatic testing is 5/3 of service pressure.
                  So if you expect 100psi on the pipe... About 166psi.
                  No harm in going higher though.
                    Water first then add a little CO2 spritzer.
                    It is dangerous so be carefull and warn others working in the vicinity.
                    Oh,I do this on pipe alone before tub/shower valves installed
