Winches?
  • Winches?
    Any of ya'll use winches? Have any brand recommendations?
    I need one with about 400' of cable. Only lifting/pulling less than 1000 lbs.
    Thanks for any opinions.
    Re: Winches?
    I doubt you will find a 400' winch but are you looking 12V, 120 volt, gas powered or hydraulic? Also it might help to know what you need it for.
      Re: Winches?
      http://www.warn.com/works/pullzall/corded.shtml
        Re: Winches?
        i thought you were talking about something else
        the only dumb question is the one that is not asked!
          Re: Winches?
          I am guessing you going to have a hard time finding a winch that is that light with that size of drum,
          I have made a few out of right angle gear boxes, 50 to 1 ratio or 52 to 1, (with hydraulics you can adjust the pressure to stall out the winch so the cable is not over loaded,)
          one may consider a Capstan winch and a proper rope,
          one thing winches are rated on the drums first layer pull if your wanting that 1000 pound of pull on the out side of the drum you will need more, rating, normally,
            Re: Winches?
            I have some multi winches. OK and cheap also grainger has them. They don't make a 400' winch in what You want. WHY 400 FT.???????? ARE YOU GOING IN THE MINING BUSS.???
              Re: Winches?
              I had thought of a capstan as well but needed to know what it was for first.
                Re: Winches?
                this is about as close to the specifications you list, I know of,
                https://www.surpluscenter.com/item.a...atname=winches
                note: this unit is with out power supply, but the drum would hold the cable required in the pull you list,
                8000 LB. WORM GEAR WINCH
                Brand new, RHINO WINCH. Made to be driven with a vehicle PTO shaft, with an electric motor or a hydraulic motor. Fully automatic safety brake and dog clutch for free-spooling. Built with a safety factor of 3:1. Enclosed gears run in oil. Roller bearings.
                SPECIFICATIONS
                8,000 lb. rated line pull
                29:1 gear ratio
                Input RPM max. 1000
                Input shaft 25 mm. dia. x 1-1/4" long w/keyway
                Drum Dimensions
                4-1/8" diameter hub
                10-3/4" diam. flange
                9-7/8" between flanges
                Drum Capacities
                325' of 3/8" cable
                470' of 5/16" cable
                735' of 1/4" cable
                Overall winch size 24" x 14" x 12-1/2"
                Shpg. 160 lb.
                this is similar to the winches I have made in the past,
                  Re: Winches?
                  the same one i looked up yesterday in their catalogue
                    Re: Winches?
                    BHD' I'm impressed GREAT fab. job
