Eternal Hybrid Hot Water heater???
  • #46
    Re: Eternal Hybrid backfiring.
    I'm mixxed about the whole Tankless thing, I want to like them and install them, but with the problems they have I'll stick with the tank.
    Will Rogers Plumbing
    Moore, Oklahoma
    405) 323-2852
    www.willrogersplumbing.com
    • #47
      so i just read this thread again, all 46 post.
      i've been a big non supporter of the tankless revolution. it's all about the green. the green that goes from the customers wallet into the plumbers wallet.
      but i've installed 5 tankless in all. 4 new installs, and 1 replacement. the first one was at my house since the heater i purchased at a discount for taking the noritz class, i couldn't sell to any of my customers with a clear conscience. so after 3 years of sitting on it, i decided to retire my 19 year old tank heater and install the noritz. not an involved install as i installed it outside next to my gas feed for the pool and hot and cold feeds to the garage. so i had all my lines within easy reach. no circ line at the time.
      after getting an earful from joey if my little forum experiment was over, i had to install an on demand circ pump. just to speed up the delivery of hot to the kitchen and master shower.
      the 3 other new installs, i had no real choice. they wanted an outdoor heater with no metal 30'' x 30'' shed. so tankless was the only real way of doing that.
      the replacement was for a customers unit that was less than 6 years old and the tech they had service it, ripped them off big time. 1 month later it was toast.
      i still feel that all the hype on tankless is just hype. and unless they get serviced on a regular basis, they will be toast.
      it still amazes me how many people are not aware that they need to be properly flushed and serviced, considering they came from a tank unit that they never flushed. also amazes me how many installations are still being done wrong.
      glad my customers listen to me and don't force it upon themselves without my ok.
      • #48
        I agree 100%. Unfortunately, the damning information hasn't gotten out to the great unwashed. They keep asking for these things.
        • #49
          I was waiting for you and Wiil to figure it out. Early on when you drank the Eternal kool-aid, I just sat back and waited.
          It's not just the hardness but the high chlorine added to the warm water for disinfection is the biggest problem, it attacks the lousy welds of the tubes in their tanks.
          Rick, I thought you had a Rheem/Ruud/Paloma unit?
          • #50
            Yeah, my big thing is getting parts in a timely manner.
            www.ballplumbing.net
            • #51
              Re: Eternal Hybrid Hot Water heater???
              Worst investment I've ever made. I own 4 assisted living homes and I put an Eternal in each home and one in my own home. $4000 a pop is a large pill to swallow. I have had the units about 2 years and I've already had to replace 2 of the units because of product defects. One of the units (in my personal residence) has been replaced about 6 months ago and I am sitting in my living room right now waiting for the technician to come and replace it for a 2nd time. These units are LOUD and I can't even fill up a bathtub with hot water because the flow rate is terrible. If we want a hot bath, we have to fill up the tub with the shower instead of the normal bath faucet. If I'm doing dishes (by hand, not with a dishwasher) then nobody can shower because there isn't enough hot water. I hate these units. I would rather have a kettle and fire burning stove than the Eternal Water Heaters. DON'T WASTE YOUR MONEY.
              • #52
                Ranting about a unit without relevant information is useless. What size unit, proper gas pressures, flow restrictor capabilities, what defects? I'm not saying that these heaters don't have issues but an improper installation, application or expectations will ALWAYS give you problems.
                • #53
                  Did you do these installations yourself?
                  • #54
                    The Eternal Condensing Hybrid's innovative 3 cycle process pushes heat in 3 directions through the water and maximizes energy transfer. In simplest terms, their patent slows the exhaust of heat by reusing the energy multiple times, rather than reducing water pressure.
                    "Ruhrpumpen.com" Leading Manufacturer Of High Quality Centrifugal Pump
                    • #55
                      So here is a question for all of you guys that have been beating the drum for Eternal Thankless water heaters. What do you tell all those customers that you sold and installed these units for with the 10 ye.. I mean 15 year warranty, now that Eternal is now eternally gone under?
                      • Bob D.
                        Bob D. commented
                        Editing a comment
                        Sorry, better luck next time. :-)
                      • SewerRatz
                        SewerRatz commented
                        Editing a comment
                        I have to have to say that to some commercial customers that have Noritz Thankless heaters. Noritz discontinues a model and when one of the 7 that are installed goes down that requires replacement, the are SOL since all the models must be the same model that connect to the system controller.
                    • #56
                      I have at least 10 in stock in various condition. One was sold to me factory refurbished for some reason, Eternal sent me another one and never followed up on the return. Another is perfectly functional (was about a year old) but the recall part failed before we could get to it and the home owner yelled at Eternal enough to send him a new one (and pay me to swap it out). I kept the original one. The only one we installed that had an issue beyond the recall part developed a leak at the condensate trap at the bottom of the heater and rusted the tank bottom a good bit. Eternal paid me to swap that one out as well but did not follow up on the return so I still have it. It was and still is perfectly functional other than heavy rust at the bottom of the unit.
                      I have a few that I removed that other plumbers installed and I decided to keep them just in case. All had mild issues (mixing valve failure, gaskets, o-rings, etc) but the home owner decided to cut their losses upon hearing of Eternal going out of business and had us install another brand.
                      I bought a NIB unit on Ebay very very cheap just in case one of my VIP customer's units has a failure.
                      All said, I think I am prepared for any potential unhappy customers. Other than that the dozens and dozens that we installed are still working, including mine.
