Mini Excavators
  • Mini Excavators
    Someone here must have owned or used a Dig-It Mini Excavator in the past. I've heard of one for sale in the area but don't know anything about them, as in what to watch out for, weak points, maintenance headaches, etc. Can anyone give me a little background on them? I did a Google search and got a couple YouTube hits but not much more. Did find one for sale for $9500 but don't know how it compares to the one for sale here as far as condition or age, or run time.
    A bud is going to snap me a photo with his cell when he drives by this week, then I'll have an idea what condition this one is in. Till then I'm trying to learn more about the beast and decide if its even worth considering for light trenching work.
    Re: Mini Excavators
    I own a Dig it 148, its the tow behind unit, that you can take the drive wheels off and put caster wheels in its place so you can push it through a 36" wide opening. The unit digs very well. I have a 12" and a 24" bucket for it. You can get a 36" bucket as well. I also have a 36" flat blade used for backfilling.
    Was built here in Mendota IL at HCC, then Yazzo bought them, If I recall Pug Industries owns the rights now. It uses a Bradco hoe which is the same hoe used on the bobcats and such.
    http://www.feterl.com/Pug/htdocs/dig_it/index.html
      Re: Mini Excavators
      i ebayed "dig it backhoe". then clicked on " completed listings". left column half way down. breid.................
        Re: Mini Excavators
        Thanks to you both for the quick replies.
        I'll let you know what I find out later this week.
        Meanwhile, I'll cruise eBay and see what I can see there.
          Re: Mini Excavators
          Ron, how is this thing tagged? As a trailer or as construction equipment in transit?
          Wondering about how/if it gets registered, insurance, tags, etc.
          Also, can you tell me a bit about the flat blade. Where does it mount for instance,
          cause looking at it I'm not sure.
          Using the same backhow as the Bobcat should make parts easy to get.
            Re: Mini Excavators
            Here in Illinois its is construction equipment in transit. It does have taillights and turn signals.
            The bucket comes off and the backfill blade goes in place of the bucket. I have the quick disconnect attachment, which means I just have to remove one pivot pin and the other just hooks on the hook. I will try to get some up close pictures for you.
              Re: Mini Excavators
              Thanks, i thought it might go in place of the bucket, but wasn't sure.
              Appreciate your help Ron.
                Re: Mini Excavators
                Ron does your unit move around in lawn and mud very well those tire look like street tires?
                Seattle Drain Service
                  Re: Mini Excavators
                  They are street tires, but it does move around real easy. Never got stuck in the mud.
                    Re: Mini Excavators
                    Ron, that is seriously the cutest little excavator I've ever seen....
                    Unless it was that cute laborer chick using a shovel on a road crew last week.
                      Re: Mini Excavators
                      Ron , you wouldn't have a good number for Pug or some other parts source would you? I tried the email and phone numbers on their web site but no reply and no answer on the phone.
                        Re: Mini Excavators
                        Ron , you wouldn't have a good number for Put or some other parts source would you? I tried the email and phone numbers on their web site but no reply and no answer on the phone.
                        When I needed parts I went to the local Ditch Witch dealer that was selling them. They might be a help to you. It has been a while since I needed any parts.
                        Ditch Witch Midwest
                        124 North Schmale Road
                        Carol Stream, IL 60188-2199
                        (630) 665-5600
                          Re: Mini Excavators
                          This was a great digger for LP tanks and underground gas services in FL.
                          We will see if the pic worked?
                            Re: Mini Excavators
                            Peoples Gas in Chicago used the smaller tow behind dig it for years. I still see them around here and there.
                              Re: Mini Excavators
                              Ditch Witch Midwest
                              (630) 665-5600
                              I will give them a call tomorrow. No dealer close to me (over 100 miles away), so might as well support someone who has sold and worked on them in the past. 100 or 700 doesn't make much difference...maybe a day in shipping. The motor mounts are the thing I am having trouble locating locally.
