Electric tankless waterheaters
  • Re: Electric tankless waterheaters
    Originally posted by Kevin Jones View Post
    Why are you answering for Rick? He posted it.
    It wasn't an answer, it was a statement. How is a Seisco a better quality than a Bosch?
      I never said it was. I said this is what they have and they are happy.
        On the other hand someone else is miss quoting btu demands and is off base. I called him on it and now I am getting kicked for knowing my stuff. What is up with that?????
          I gave a real example of a real family that is happy and I got the details as requested. I did my work.
          On the other hand I get paid to size systems.
          To be honest I doubt there are many here who would need your help sizing anything. An unrealistic demand is a poor example of success.
            Ok so why didn't anybody else answer? Tanks are not the only answer but the truth of the options is shuned?
              You said Bosch was junk, I was merely pointing out Seisco is worse.
                Answer what? Between the two of you who can follow a thread.
                  Fine if that is your opinion. I'm not taking offense. I have said this unit is working for them. If it is a POS then they got lucky.
                  It is still a real example. Why are you taking offense?
                    The original question...getting 10 gpm by electric.
                      I still think Bosch is junk and will never install one given a choice. Now I know a unit I didn't install and is working just fine is an even bigger piece of junk...guess what I will consider to not install the next time.
                        I have learned something from others opinion.
                        Is this Mother Russia during the cold war or is this the USA and I can speak?
                          I'm not offended in the least simply realistic. I posted a buddy has a 1.0 gpm electric heater. He may be happy as well but he is sacrificing.
                            Your buddy got screwed.
                              That depends on the max load of the unit.
                              Look at the coldest ground water of the year. Then take the difference of the temp desired. Say 70 delta T. Then put that into the performance chart of the unit you have available.
                              This is not a guess. If you have 50F water in Jan. and want 130F water then the delta T is 80. The manufacturer gives a chart that tells the gpm on that delta T. If it is 6gpm then 2 is good. If it is 4 gpm you need 3.
                              You don't want the unit running 100%. So give a 20% deration of the chart performance. That may require 4 units.
                              Okay, there is your formula now make it make sense with a normal panel.
                                He installed it and it's what he wants. I thinh he's crazy but I would not use him as an example.
