zoeller pump
  • zoeller pump
    Custome had a zoeller installed 2 years ago in a sump pit. When the pit fills, pump kicks on and trips the breaker. I took it out to see if there was any debris in it and found nothing. Any ideas?. Pump is around 200 new, don't think its worth having to have it looked at
    Re: zoeller pump
    what kind of draw in amperage is the pump pulling? Measeure with ammeter than compare to spec for the model number. There are many possibilities other than just the pump going bad.
      Re: zoeller pump
      if it is plugged into a gfi outlet try one without
