IPC-Boring Sideways
  • #31
    Re: IPC-Boring Sideways
    Originally posted by MoJourneyman View Post
    I did think it was funny that they ignored the cleanout requirement when they wrote that code. leaves a 2 inch access to a 3 inch line. but hey, washer lines never back up
    our inspectors there interpreted it as a 3" 45 with a 2x3 bushing in it under the floor, and a 2" 45 above the floor in the wall, if it was on an outside wall anyway.
    No P-Traps in an exterior 2x4 wall. Got you again. (J/K)
    • #32
      there I go again, noobing it up in public.
      I'm here to tell you, coastal nunya has a LOT of traps in exterior walls, along with non frost free hose bibs in those 3.5 exterior walls.
      heading to bed. I enjoyed the back and forth.
      goodnight all.
      • #33
        As a carpenter, what do You want for walls under the UPC.
        Laundry and kitchen 2x6 for 2" waste ???
        • #34
          If Pa, ever adopts this version of the IPC, I'm just going to tell our carpenters to use a 2x6 wall for the laundry area.
          • #35
            Inspectors will also use it at your kitchen window where it may be headered off with full studs and short studs. More than 4 over to your vent, no drill.
            • #36
              I.P.C. 305769 Max window kitchen sink width 14 1/2" .
              • #37
                Carpentry ABC-123. Double stud at casing, 3 shorties under header, inspectors will call it here.
                No habla espanol carpentry.
                • #38
                  New market for portholes, Mom won't be happy !
