What happens when idiots play with gas !
  • What happens when idiots play with gas !
    NOTICE IN PRINT THAT THEY BYPASSED THE GAS
    METER SHUTOFF AND REGULATOR AND HAD HIGH
    PRESSURE GAS IN THE BUILDING !
    http://abclocal.go.com/kabc/gallery?...584168&photo=1
    http://www.cbsnews.com/stories/2010/...n6728367.shtml
    JERRYMAC
    E-MAILJERRYMAC777@GMAIL.COM
    FIRE SPRINKLER CONTRACTOR,
    SINCE JAN. 1989
    Re: What happens when idiots play with gas !
    I use to have gates and other projects powder coated in Oakland.
    they're out of Buss. I can imagine the Gas bills Must of been Huge for
    the walk in ovens. Bet they bootlegged a hookup after it was turned off. By Gas Co.
      saw it live on the news this morning. originally thought is was an acetylene leak, but now it looks like they were stealing natural gas.
      don't think it makes a difference if the pipe was gal or black
        NOT EVEN IF WAS THE WORLDS BEST CSST TUBING
        IT ALL GOES BOOM WHEN IDIOTS MESS WITH IT
        JERRYMAC
        SINCE JAN. 1989
          What is the gas PSI in the street for commercial use in L.A., and other cities ? 50 LBS ? Thanks Tool
            Because they have to pressurize it it has more to do with the demand on the main but 50 psi is about right. The high pressure lines running across the country can be over 1,000 psi.
              story said owner turned on a propane furnace in the morning. high pressure ng to an unconverted and unregulated prop furnace raised the iq level in cal about 3 points. breid.....................
                After this man made disaster, Gas and Power Co.s would do well to inspect all shut downs on a routine basis. I wonder how many more
                bootleg hookups are out there in these hard times !
                  after this man made disaster, gas and power co.s would do well to inspect all shut downs on a routine basis. I wonder how many more
                  mooooocho
