Too Much Glue
  • Too Much Glue
    As long as we're discussing flux and leaks that happen years down the road.....I ran into this today.
    This is what happens when too much pvc glue is used, especially if it is used in the socket side of the connection. This irrigation system was installed about 10 years ago.
    The big crack goes all the way through as evidenced in the first photo. You can see the sheen of the glue all the way down the bottom of the pipe and the spider cracks appearing.
    The last photo is the finished repair.
    Re: Too Much Glue
    I'm not sure I've ever seen that happen. How do you know excess glue causes cracking like that? I'm asking that question, because I don't know.
    I think we've all been guilty of using too much glue at one time or another.
      Re: Too Much Glue
      Mmmmm...You can see and feel the glue all down the inside bottom of the pipe and the cracks only form in that. I've cut dozens of feet of failed pipe out over the years. And last but not least, the back of the glue can states it pretty clearly.
        Re: Too Much Glue
        Hmm...I'll have to look on the back of the can tomorrow. I couldn't find anything on Oatey's website.
          Re: Too Much Glue
          What does it say on the can ? I wonder does it cause the pipe to get brittle and hair line crack or eat thru the p.v.c. over time ? I know if the joint is not wiped it is so pose to make for a weak joint but this I have never seen . Good pictures Slim
            Re: Too Much Glue
            The only thing Oatey says is don't use to much glue, but they don't say why. They also say to not let the glue puddle up inside the fitting/pipe, which can be hard not to do sometimes.
            What you see on the video..is not realistic out in the field.
              Re: Too Much Glue
              It doesn't cause it to get brittle, it causes it to get soft. And I probably should have stated this at the outset but forgot, the pvc pictured is class 200 which is standard for irrigation work around here. But, two years ago I cut out a 1" schedule 40 ell that the glue had puddled in and caused a crack. It took longer than 10 years for that one. I think I have a pic of it somewhere. I'll post later.
                Re: Too Much Glue
                Here is a 45 that the glue had puddled in more than 10 years ago. The bulge (which was actually the bottom of the fitting) corresponds to a hard puddle of glue that was inside the fitting (which doesn't really show up in this photo sorry).
                  Re: Too Much Glue
                  I ran across a situation where too much glue turned a 3 inch pvc bushing to rubber and it blew apart. The glue was spilled on the outside honeycomb portion of the bushing. It flooded a nearby classroom. Very expensive disaster.
                    Re: Too Much Glue
                    Wow! That's an awesome story. I wonder what the *#@%! k!*#z was thinking when he poured the glue in the honeycomb part of the bushing, "now dis aughta make it stronger"....
                      Re: Too Much Glue
                      Are you sure it's glue and not just sap from a river birch tree?
                      I love my plumber
                      "My Hero"
                      Welcome, Phoebe Jacqueline!
                        Re: Too Much Glue
                        Women sure do have loooong memories.
                          Re: Too Much Glue
                          For your information, the sap from a river birch tree DOES make the fitting stronger. You should try some.
                          How's that little sapling of yours coming along? Ready to sprout?
                            Re: Too Much Glue
                            And an internal filing system that can produce the slightest, flippant remark one may have made over 22 years ago during a lengthy (painful) labor with one's first child. Amazing and disturbing (and annoying).
                              Re: Too Much Glue
                              Just about. Doctor said probably 2 more weeks. These contractions must be my karma for making fun of you though!
                              I love my plumber
                              "My Hero"
