Straight tub shoe?
  • Straight tub shoe?
    I am installing a freestanding acrylic tub soon and have a problem. There is already a p-trap in the floor exactly where the tub waste is located on the tub. It doesn't have an overflow and there isn't access to the underside of the tub. Does someone make a straight tub shoe/waste? I could use an 1-1/2" fernco down below on the 1-1/2" pvc and then lower the tub down and screw in the waste. Thanks.
    Re: Straight tub shoe?
    The lake house that will still are working on has a similar tub connection
    The over flow is built into the tub it self and the drain is more like a large PO plug you set the tub with the drain connected into a tye seal gasket below the slab
    I haven't seen the tub yet just the rough in pics
      What you are looking for is called a tray waste around my area. Manufactured homes don't have overflows on the tubs, so they are very popular around here.
        Female adapter with a push/pull Watco?
          The tub drain came in to day here's a few pics of it
          Of course you would have a closed opening
            Not sure exactly what you need but it sounds like you want a tub drain without the overflow connection.
            Does this help?
            http://docs.google.com/viewer?a=v&q=...cRyCPeSYvs4XsA
              I would like to find one that I dont have to knotch the joist every time also.
