Back outlet toilet
    Re: Back outlet toilet
    Originally posted by geno gardner View Post
    You use a regular flange that just happens to be mounted on the wall. Make sure you use a wax impregnated felt ring and not a wax ring with a little felt inside it. You'll be glad in a year or so when you don't have a leak you're responsible for.
    Agreed! Learnt the hard way on this one.
      See..That's what I mean.If Duravit would provide a installation manual on their
      HAPPY D. # 017009
      I could see if that was a carrier designed toiled.
      I don't see why a floor mount needs one.
      What am I missing
      Add:
      Except of course a height for outlet
        We have a few floor mount rear outlets here..They Just sit on the floor and have a reg flange on the wall
        Most are on septic tanks , it gives the the flusher of slow septic lines a advantage by draining up higher, than a standard com
          If the owners wanted something different you can still buy Case toilets but be ready to spend $$$$ for them
          I was pretty impressed with the last case wall hung I worked on... The guts are all brass and I think they are about a 4 gallon flush
            Go here and click on the Technical Drawings below the picture.
            http://www.duravit.com/products/seri...seo6q3rqe.html
            There are several options & measurements in mm that you can convert if needed.
            They show multiple ways to connect it with a dimension on each.
            If I run into something similar I make them order it and have it on the job at the rough-in because I don't even trust the drawings.
            On a side note, this looks like some "I wanna' be different than you and you not have it B.S."
            Good luck A.
              I believe the Duravit floor mounted rear outlet height is 8", but I haven't installed one in a few years, it would be my first choice for a rear outlet floor mount tank type toilet, though I prefer the Duravit concealed tank toilets.
                this should be great. any odd or custom stuff costs extra and all the time expended dinking with it is compensated. just me. breid...............
                • #23
                  I'm with Rick on this subject though, Floor mounting with a rear outlet doesn't make any sense to me plumbingwise and gains the owner zero advantage over a standard toilet.
                  I rough-in / install floor set, rear outlet toilets when I have a situation where a toilet will be located on a floor constructed of 2x6's. To maintain structural integrity of the framing I try and keep cutting and drilling joists to a minimum. The reason really doesn't have anything to do with plumbing per se.
                  • #24
                    I have often wondered about your toilet pans (W/c) as you call them and if you used P pans (back outlet toilets) as all I have seen are S pans through the floor on this forum we use wall hung P traped pans where the pan is bolted to the wall but most are screwed to the floor with a meriod of pvc connectors sold with the toilet pan to accommodate most situations either through the floor or wall and your wax seals must be a pain in the A+++ where we use a pvc pan collar with a rubber seal which the pan outlet is pushed into.
                    Tony
                    • #25
                      Tony
                      toto toilets are floor mount with the rubber seal on the high end toilet with the plastic sub flange assy. not a bad set up, but the footprint puts us very close to hitting the rear wall and our angle stops that are standard 6'' high and 6'' left of center.
                      i think it's time for an exchange student program
                      • #26
                        PASS on this Guy , What's next ceiling mount ?
                        • #27
                          Holy Smokes,
                          KTS on a high speed flyby.
                          8" saves the day bigtime.
                          Thanks,good to hear from you.
                          Been doing any 50 cal. hole punching this summer.
