Old copper gas lines underground
  • Old copper gas lines underground
    Just found out a few towns over, they're digging them up.replacing with plastic. Are they in Your city also ??
    Re: Old copper gas lines underground
    I've ran into them.
    Got called out by the General,he sawcut into it.
    Manifolded in wall like Potable.
    With Solder
    Gave them a price for overhead steel.
    Didn't get it.
      found them when it's time to sell and they need to install a seismic shut off valve.
        I work wita fair amount of copper 2lb gas systems. Underground I use either copper or polyethylene plastic gas pipe. The copper gets brazed joints or flare and the polyethylene uses a stainless steel compresson type fitting with a rubber seal.....just tightens on.
        In the eearly 90's a customer purchased some decorative gaslights and called me to install them. I opened the box's and they had 1/4" compression fittings on the lights inlet connection. I commented.."I cant install these..they are not built to code....who sold you this?" (I use to be gung-ho code) The lady says..."From the gas company" I said well get them on the phone for me and I will set them straight on this...it should be a flare fitting" About 30 minutes later the guy from the gas company shows up at the house and basically told me to stfu and install the lights...because they are outside and 10' up on a pole. i stfu and installed the lights. The gas company here inspects and assumes all responsibility so I did what the man wanted.......he did break down and tell my customer I was technically correct but the connections are safe. Eventually the lights they sold had flare fittings and not compression.
          We have copper gas lines in our neighborhood, most houses were built in 1969. Don't know of any problems. I dug around one last year when I was replacing my orangeburg gutter drain pipes, the copper looked like new.
            talked to ARB in S.F. today. They're changing out the copper to
            plastic. They were having lunch. I told them "My house stinks of GAS!"We had a laugh, after. Boss [ 42 years in the trade] said the old copper [70 years old] flakes off from the inside! They won't for get the Irishman!
              HEY THEY'RE NOT SCRAPPING OUT OLD THE COPPER !!!!!
              How would You get it out ?? Truck winch ??
