T&p?
  • T&p?
    Where do you pipe your T&P when the W/H is under a sink?
    Thanks.
    Re: T&p?
    condensate pump dumped back up into sink
      Re: T&p?
      I don't know about that one tool.
      How would an illegally installed undercounter waterheater T+P blowing off at full volume be kept up with by a condensate pump.
      I think that is why the code states we need to get them piped to the outside.
        Re: T&p?
        i'll assume it's an electric heater. out here if the heater was installed prior to the enforcement of t & p valves, the heater is in the middle of the room/ not on an exterior wall, then a variance could be issued. the cost of the variance is expensive, but it basically releases the city and plumber from liability.
        same scenario on a gas heater. but a watts #210 could be substitute for the t&p. problem is the city of la banned their use years ago.
        rick
          Re: T&p?
          Thanks Adam, I had My doubts on that also !
          If someone else posted that,I woulda Jumped all over them !
            Re: T&p?
            On the other hand, You could use a 3 phase 5 H.P. condensate pump!
              Re: T&p?
              rick
              Kind of what's going on. They want a small heater under a kitchen counter in a commercial setting. (Maybe 10 gallon). No way to get a T&P out anywhere.
              I think our "easier but not necessarily better" IPC only requires it to terminate in a "visible place by occupants...."
              Thanks.
                Re: T&p?
                Punch a hole in the wall and put it outside
                  Re: T&p?
                  Can't. Think of being in the middle of a room with a slab floor.
                    Re: T&p?
                    Doooohhhhh
                      Re: T&p?
                      Like our 2000 gallon condensate recovery tank that sends it back to the powerhouse boilers, and that is only for one building.
