WELL, I like the grundfos JPS4 well pump
  • WELL, I like the grundfos JPS4 well pump
    Stainless 1 hp $458.87 230V or I could use the 1/2 HP one. Either one i can use with out a tank for shallow well. This was recommended Be a local Well co. Any Thoughts ?
    Re: WELL, I like the grundfos JPS4 well pump
    I don't care for stainless housings. I don't have any good data to offer you as an argument against them however. It is more me just stomping my feet and saying cast iron is better because that's what I've grown up using.
      Get a goulds or a F&W. I have a dumpster filled with Grundfos well pumps gone bad
        I really like the Sta-Rite jet pumps, alot of bang for the buck and never had a call back on one.
          GOULDS J10S IT IS ! Should I add a 32 gal flexcon tank. Open shallow cistern about 1500 gals now in the driest season. Dedicated for animals and garden only. Just thinking tank
          would make less cycling for motor. Thanks tool
            Yes, add the tank. Pump cycling is the #1 cause of pump failure
              As someone (I think Speedbump) stated before, soooooo many pumps made by Pentair & ITT that are just rebranded. Many or all with the same Franklin electric motor.
              So, I don't think one can take all the "this pump is better than that one" as seriously as one once could.
              Did you know that Franklin started making the complete pumps? Last I heard they were losing their azz on that though.
              Not long ago I picked up a pump that had always used Franklin that had a different motor. I'm guessing Pentair didn't like the competition.
              Just some info. Good luck Tool.
